Ch.9/pg.7
1) When the voltage is stepped down with the PT doesn't the current then get stepped up to a dangerous level for the voltmeter to measure the circuit?
2) When the current gets stepped down via the CT, the voltage is now so high, why is this acceptable here vs. in the PT scenario?
3) Why isn't this ground(grounded for safety) causing a direct short?
