I am sure this will be a very basic electronics question, but I am ignorant on this and would like some help. I have purchased a Chinese inverter welder/plasma cutter. The machine runs off of 24 mosfets and apparantly some people have had issues with the mosfets blowing(mostly when using the plasma). My question is- IF I were to have a problem and wanted to replace the mosfets here in the US, what would I need? I have one unit that has, I believe ,toshiba fets with the numbers FEP underneath that is the number 25N50G and below that is 70842. Here my ignorance will show. I believe the fet is a 25 amp 500 volt unit(that is all the info I could get from looking on the net). Are there different switching speeds or would any 25amp500volt mosfet work? Also I have heard that IGBT chips are more sturdy in this application would that be just a simple swap? If so what IGBT chips would I look for. I also have another unit that has a different mosfet that I may need a cross reference to as well. Thanks again Mark
