Hello , Im building a circuit transform 12vdc to 220vac using pwm in atmega16 to create a sinewave on the output but the problem is that the the output gives a strange wave so i guess that my code is wrong .
Note : Im using winavr and i chose PORTB and fast PWM .
I post a pdf file about my circuit and the code .
Please i really need help and thank you very much .
The code is :
The code is :
Rich (BB code):
#include <avr/io.h>
#include <avr/interrupt.h>
static void avr_init(void);
volatile uint8_t x ;
int main(void)
avr_init();
for(;;)
// Tasks here.
OCR0 = x ;
return(0);
// Initialize device here.
DDRB = 0XFF ;
TCCR0= 1 | _BV(WGM01) ;
//| _BV(COM01) | _BV(CS00) ;
TIMSK |=_BV(OCIE0);
TCCR0= _BV(WGM00) |_BV(WGM01)
|_BV(COM01) |_BV(CS00) ;
PORTB = 0 ;
sei();
return;
ISR(TIMER0_COMP_vect)
x+=200 ;
