Hello all,
Just joined the site and making my first post.
Worked in Electronics many years ago so basically familiar with it but my knowledge has deteriorated due to old age!!
I'm here on an offshore drilling vessel off the coast of South Africa.
One of our treadmills crapped out. When the treadmill is activated it goes bonkers. I've tested motor and went through all of the connections. I've tested the current draw and didn't see anything that would cause it to shut down. No current spikes, no voltage drops. The controller is running off a small Microchip controller of some sort.
Anyway. I'm wanting to rig up a manual control for the treadmill to get us through until a replacement arrives.
Ive got limited access to electronic parts but I do have enough parts to make the 555 pwm circuit listed HERE.
I've built that circuit many times and used it for many different things but never to drive a motor rated at 160v.
How would you interface this circuit to a 160v DC circuit?
I've got a couple MJ11021 & MJ11022 that would work I think but don't want to burn up all my parts experimenting!!
One idea I had was to use some type of buffer circuit to connect Pin 3 to the Darlingtons.
Any help??
Thanks!!
386
Any help??
Thanks!!
386
