pwm using 555
Discussion in 'The Projects Forum' started by fourty, Sep 8, 2014.
  1. fourty
    Oct 13, 2013
    13
    hi i designed a pulse width modulator using 555 the problem
    is that the magintide is not stable,i simulated the circuit in multisim and with a breadboard using osciloscope plz can someone help me?
  2. wayneh
    Sep 9, 2010
    12,379
    3,234
    Are you saying that the simulator and the breadboard with real components BOTH produce that waveform?
  3. fourty
    Oct 13, 2013
    13
    yes:((( i can't find the problem
  4. wayneh
    Sep 9, 2010
    12,379
    3,234
    I honestly don't know how to get that output from a 555. Scope the voltage on the timing capacitor. Maybe it will yield a clue.
    fourty likes this.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Curious, where did you get that circuit?
    A common and different version is here:
    John
  6. wayneh
    Sep 9, 2010
    12,379
    3,234
    Or, closer to home, there's the 555 PWM section of Bill's blog. (Oddly, that link fails for me right now. Hopefully it works for you.)
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  8. tom_s
    Member
    Jun 27, 2014
    287
    342
    same picture both locations :) playing around with that circuit now and it works like a charm
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
    Which "both." Obviously, the schematic I posted and the schematic in the link for its source are the same, as one would expect.
    However, the schematic posted by the TS is different. Look at the output/gate drive. In the TS's design, the "output" (Pin3) is used presumably for the gate drive, at least that is the source for the oscilloscope trace. In the DPRG design, "Discharge" (pin7) is used. Pin 7 is used in several designs as an output, but it is not the same as pin 3.
    John
  10. wayneh
    Sep 9, 2010
    12,379
    3,234
    I'm still at a loss to explain how you could get that trace on the output pin of a 555. I would say it's a measurement artifact (such as a shifting ground) but the OP says the simulator gives the same result.
  11. tom_s
    Member
    Jun 27, 2014
    287
    342
    thanks John, deem my interpretation of 'A common and different version is here:' incorrect
    i read as A common (as image displayed) and assumed and different version is here: as another version.
    kind regards,
    Tom
