PWM Trouble with PC Fan
Discussion in 'General Electronics Chat' started by tony48, Mar 1, 2014.
  1. tony48
    Jun 11, 2013
    I'm trying to use a PWM controller to control a 12v PC fan. When I wire it up, it controls the fan as expected but there is a loud squealing noise coming from the fan that changes pitch when I change the fan speed. Can anyone help me understand why this is happening and hopefully fix it?
    Here's the PWM unit I have:
    http://www.amazon.com/LEDwholesalers...1&keywords=Pwm
    Thanks very much!
  2. shteii01
    Feb 19, 2010
    3,519
    515
    Looking for something?
    We're sorry. The Web address you entered is not a functioning page on our site
    The blade might be unbalanced. When the speed changes, the blade wobbles and hits the fan frame.
  3. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Bad bearing in the fan? Can you take the fan apart and get to the bearings? Perhaps a bit of lubricant will get rid of the squeal for a while.
  4. tony48
    Jun 11, 2013
    The sound is not present when I run the fan without the pwm circuit. It is a distinctly electrical squealing sound
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    The base frequency of your PWM circuit may be in resonance with the fan producing the sound. Can you change the base frequency to something higher or lower?
  6. tony48
    Jun 11, 2013
    I'm kind of inexperienced and not sure how to do this
  7. tony48
    Jun 11, 2013
  8. #12
    Nov 30, 2010
    16,705
    7,358
    That's not a chip. It's a completed module. If you're going to change the frequency, you're going to have to dig inside the box and find out how it's made.
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    12v PC fans only use about 50mA to 100mA, you can fix this by putting a resistor between the module and the fan. And a large cap (1000uF) across the fan wires. A resistor of 10 ohms should do it.
    An inductor can work better than the resistor but is harder to find and can cause other issues.
