Hi!
I'm about to design a circuit that will convert a PWM signal to a bar with 20 LED's. The PWM signal is locked to 300hz and 12Vpp with an offset at 12v. The signal is also inverted (100% duty when the level is at 0V.)
I want a LED bar with the resolution of 20 LED's to represent the duty cycle. I.E 50% equals 10 LED to be lit and 60% would result in 12 LED.. and so on.
My first thought is to use a second order low pass filter and a LM3914N (dot/bar display driver) but i have some trouble finding out which components and values to use.
I'm from Sweden but I hope I made my self understandable.
Thank you in advance!
