I've been dabbling with electronics for the last month or so and came across a project that I wanted to attempt.
I want to use a PWM with adjustable frequency set at about 20Hz-50Hz frequency on a 30A solenoid.
After a bit of research I found a schematic that I thought would work.
I was able to wire up the schematic and even test it on an LED and it worked, however once I tried it on the solenoid it did not work.
I bought a NE555 Nano Pulse frequency Duty Cycle Adjustable Module Square Wave Signal Generator with adjustable frequency (1Hz-50Hz) from ebay. (I'm not sure if I am allowed to post the link to the NE555 on here or not)
The solenoid draws 30A and needs to be pulsed anywhere from 20Hz-50Hz.
I used the following schematic. (see attachment)
For the transistor I used a 2N3055G
The resistor is a 10K
The Diode is a 1N4007
When I tested it on an LED it worked real good, I could change the frequency and the duty cycle and the LED would do as the module would direct it to.
However, once I tried the PWM on the solenoid the LED would turn-off, but the NE555's built in LED was still blinking telling me it was working, the LED though that I connected after the transistor would turn off.
I believe perhaps the transistor perhaps is to small for the solenoid, but at this point I am not sure. So I would like to get other opinions before continuing on this project.
Also would it be better to use another PWM as opposed to the NE555? I've been reading up on the Arduino and it looks promising as well.
Thanks in advance for any help that someone may be able to provide.
