PWM through ADC
Discussion in 'Embedded Systems and Microcontrollers' started by InfahOlic, Feb 9, 2014.
  1. InfahOlic
    Feb 5, 2014
    I am new at AVR microcontroller,I want to vary PWm duty cycle through ADC which should be an potentiometer at I/p. I need a source code for atmega8 or 16 any of them which can full fil my requirment
  2. shteii01
    Feb 19, 2010
    3,519
    515
    ADC is analog to digital converter.
    Do you mean DAC? Digital to Analog Converter?
    Are you trying to receive PWM or send out PWM?
  3. MrChips
    Oct 2, 2009
    12,657
    3,461
    OP says that a potentiometer is connected to an ADC input.
    The setting of the pot 0-100% is to be used to determine the duty cycle of a PWM output.
  4. donpetru
    Nov 14, 2008
    186
    25
  5. Rydaholic
    Feb 4, 2014
    15
    I also need help in same topic kindly if you got this please send me some kind of source code for it which i can control pwm through potentiometer and also if u tells me how to vary the duty cycle automatically using feedback. I am designing a synchronous buck converter..!
  6. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Don't steal someone else's thread. That is very rude.
    All it takes is a little searching.
    http://www.mikroe.com/products/view/285/book-pic-microcontrollers-programming-in-c/
    Oh and YOU need to provide the source code. People are here to help not do your work for you.
