PWM supply or DC power supply
Discussion in 'Power Electronics' started by sohamkul, Oct 16, 2016.
  1. sohamkul
    Jun 24, 2016
    43
    Hello ,
    I am doing a project where i am using a screen ,
    now the Datasheet of screen says that i need to power the back-light using 3.3 V PWM .
    but instead i tried using simple 3.3 V supply.
    The back-light works fine on simple 3.3 V DC .
    Question : Should i be concerned that i didn't use PWM ? or should i use a PWM ?
  2. johndeaton
    Member
    Sep 23, 2015
    50
    What you did is fine. You would use PWM if you want to dim the back-light. A constant supply will just keep the back-light on full bright.
    sohamkul likes this.
  3. Dodgydave
    Jun 22, 2012
    5,143
    768
    The pwm will be incase you need to dim the backlight easier, or use a variable dc supply.
  4. sohamkul
    Jun 24, 2016
    43
    johndeaton likes this.
