PWM signal from four wire fan
Discussion in 'The Projects Forum' started by sumit123, Nov 12, 2014.
  1. sumit123
    Oct 28, 2013
    11
    I am trying to design a circuit that read the PWM signal from four wire fan & indicate us in a form of Led or sound ,when fan stop the working or if the fan motor not working.
    Anybody help us with the circuit diagram.
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    Why not use a fan with a locked rotor alarm signal if your only intent is to see when its not turning?
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    unfortunatly when the fan fails, it is usually the bearings, and the electro0nics that drive the motor keep going.
  4. sumit123
    Oct 28, 2013
    11
    So what do you think if i use locked rotor alarm signal fan.Is it save to use or not.
  5. Dodgydave
    Jun 22, 2012
    5,142
    768
    are you trying to sense if the motor has stopped,if so use a slotted opto pickup or current sense it.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    yes its safe and its the easiest way
    They are used all the time to protect critical equipment from overheating if the fan dies.
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Mitsubishi use these 3 wire type of fans on their CNC equipment, the third wire has to indicate a high, (fan running) in order to energize the system.
    Max.
    Johann likes this.
