PWM = (pr2 + 1) x 4 x Tosc = HEadache!!
Discussion in 'Embedded Systems and Microcontrollers' started by dontventonme, May 30, 2009.
  1. dontventonme
    May 30, 2009
    im working with MPLAB 8.30, C18 code.
    using pwm.h is fine, i can get things working good.
    though calculating the proper period from the datasheet formula is a bit confusing.
    i have a few different books, and tutorials and none of them give me a clear understanding of how to make sense out of getting the proper timing for a period. What weight does Tosc hold, is it one oscillation, or many?
    im working with a continous servo, and i need to achieve 20ms or so delay with 1.3-1.8ms high time.
    if someone has a tutorial of how to properly calculate this period to get proper values (since i cant seem to get them) that would be appriciated.
    with the openPWM2( (some random value) ); i can get it to pulse, but with out the proper timing i will probably blow the servo motor.
    thank you in advance for any help.
  2. mik3
    Feb 4, 2008
    Tosc is the period of the uC oscillator (1/Fosc).
  3. dontventonme
    May 30, 2009
    ty for replying.
    so i have:
    #pragma config FOSC = INTOSCIO_EC
    this proves to be 4mhz clock stable as of OSCCON
    so then its safe to say that 1/FOSC will be 250ns
    and then to get my 20ms i would have to add a scaler to break it down
    to get it to 20ms then.
    i will play with this a bit.
    thanks for some clarity, that helps alot.
  4. dontventonme
    May 30, 2009
    period value = 250;
    ( (1/(4mhz / (16 prescaler)) ) x (period value) ) x (2 postscaler) = 20ms
    so with c18, 18f4550
    #pragma config FOSC = INTOSC_EC // 4mhz stable
    setDCPWM1(25); // gives 2ms pulse
    OpenTimer2(T2_PS_1_16 | T2_POST_1_2); // sets up scalers
    then this gave me the proper values needed.
