pwm pic16f873
chipus
Joined Mar 9, 2010
6
hello
i need some help in constructing pwm program.. i need to vary duty cycle from 0% to 100%.. interruption will occur before the duty cycle is changed.. can any one fix this program???.. :(:(
; oscillator : 4 mHZ
List p=16f8773
#include <p16f873.inc>
;***declare registeraion
ORG 20H
COUNT RES 1
AN0 RES 1
AN1 RES 1
;***port initialiization
MAIN BCF STATUS,RP0
CLRF PORTA ;clear content of port A
CLRF PORTB ;clear content of port B
CLRF PORTC ;clear content of port C
BSF STATUS,RP0 ;change to bank 1
MOVLW B'11111111'
MOVWF TRISA ;set port A as input
CLRF TRISB ;set port B as output
;***A/D conversion
BCF STATUS,RP0 ;change to bank 0
MOVLW B'01000001'
MOVWF ADCON0 ;fosc/8, channel 0=RA0/AN0, A/D converter=on
MOVLW B'00000000'
MOVWF ADCON1 ;set port A as analog input port
;***PWM initialization
;**step 1: set the PWM period by writting to the PR2 register
MOVLW D'49'
MOVWF PR2 ;PR2=49
;**step 2: set the PWM duty cycle by writting duty cycle by writing to the CCPR1RL register and CCP1CON<5:4> bits
BCF STATUS,RP0
MOVLW B'10110100'
MOVWF CCPR1L ;load 180 in W to CCPR1L
BSF CCP1CON,CCP1Y ;set bit 1 of the duty cycle
BSF CCP1CON,CCP1X ;set bit 0 of the duty cycle
;**step 3: make the CCP1 pin output by clearing the TRISC<2> bit
MOVLW B'11111011'
ANDWF TRISC ;clear TRISC<2>
;**step 4: set the TMR2 prescale value and enable Timer2 by writting to T2CON
CLRF TMR2
BSF T2CON,TMR2ON
;**step 5: configure the CCP1 module for PWM operation
BSF CCP1CON,CCP1M3
BSF CCP1CON,CCP1M2
BTFSS PIR1,TMR2IF
GOTO $-1
BCF PIR1,TMR2IF
;***1st loop
LOOP1 BTFSS INTCON,T0IF
GOTO LOOP1
BCF INTCON,T0IF
BCF INTCON,T0IF
BSF ADCON0,GO_DONE
BTFSC ADCON0,GO_DONE
GOTO $-1
MOVF ADRESH,W
MOVWF AN0
MOVWF PORTB
MOVLW B'01001001'
MOVWF ADCON0
;***2nd loop
LOOP2 BTFSS INTCON,T0IF
GOTO LOOP2
BCF INTCON,T0IF
BCF INTCON,T0IF
BSF ADCON0,GO_DONE
GOTO $-1
MOVF ADRESH,W
MOVWF AN1
MOVWF PORTB
SUBWF AN0,0
BTFSS STATUS,Z
MOVWF CCPR1L
GOTO MAIN
END
Markd77
Joined Sep 7, 2009
2,806
Have you turned the watchdog timer off? There are no config settings so it probably takes default settings from MPLAB.
I've also spotted a couple of things.
List p=16f8773 <------- change to 16f873
ORG 20H <-------- This sets the program start to
COUNT RES 1 20H, not the variable space
AN0 RES 1
AN1 RES 1
