Good deal
OK, something else I failed to research The MUR420G will be grossly inadequate to handle the current from the inductor. It's only rated for 6A, and you'll be pushing almost 3x that through it.
I suggest that you replace it with something like a STTH60P03S; it's rated for 60A continuous - or perhaps a Fairchild RHRP3060, 30A 500V. I've been poking around looking for a suitable Schottky barrier diode, but most of them are rated for < 15A. Those that have a higher rating are dual diodes, and that's not likely to work well in this application; one will get hotter than the other, thus will conduct more of the current, which makes it hotter - thermal runaway is not your friend.
ST Microelectronics' STPS20L15D/G might be worth a look. 20A, 15V, 0.33vF max. The very low Vf is attractive, but the 15v reverse voltage would be a problem if your alternator were putting out >15v.
