PWM on atmega168P
Discussion in 'Embedded Systems and Microcontrollers' started by Abdullah Zia, Nov 21, 2012.
  1. Abdullah Zia
    Mar 17, 2012
    Can any one please tell me how to generate 4 pwm signals of 50 Hz with variable duty cycle on the atmega 168 microcontroller?
    A friend was able to get 4 pwm signals but only two of them had a controllable duty cycle. (like...i could vary them)
    I wanna start with a 1 ms duty period and then later on vary it.
    he used the following code
    Code ( (Unknown Language)):
    1.
    2. #include <avr/io.h>
    3. #include <avr/delay.h>
    4.
    5.
    6.
    7. void USART_Init( unsigned int ubrr)
    8. {
    9.     /*Set baud rate */
    10.     UBRR0H = (unsigned char)(ubrr>>8);
    11.     UBRR0L = (unsigned char)ubrr;
    12.
    13.     UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    14.     /* Set frame format: 8data, 2stop bit */
    15.     UCSR0C = (1<<USBS0)|(3<<UCSZ00);
    16.
    17. }
    18.
    19. void InitPWM()
    20. {
    21.     TCCR1A|=(1<<COM1A1)|(1<<COM1B1)|(1<<WGM11);        //NON Inverted PWM
    22.     TCCR1B|=(1<<WGM13)|(1<<WGM12)|(1<<CS11)|(1<<CS10); //PRESCALER=64 MODE 14(FAST PWM)
    23.
    24.     ICR1=2499;  //fPWM=50Hz (Period = 20ms Standard).
    25.
    26.     TCCR2A|=(1<<COM2A0)|(0<<COM2A1)|(1<<COM2B0)|(0<<COM2B1)|(1<<WGM21);        //Working on CTC mode
    27.     TCCR2B|=(1<<CS22)|(1<<CS21)|(1<<CS20) | (1<<FOC2B); //PRESCALER=64
    28.
    29.     OCR2A=77;
    30.
    31.     TCCR0A|=(1<<COM0A0)|(0<<COM0A1)|(0<<COM0B0)|(1<<COM0B1)|(1<<WGM01);        //Working on CTC mode
    32.     TCCR0B|=(1<<WGM00)|(1<<WGM02)|(1<<CS02)|(0<<CS01)|(1<<CS00); //PRESCALER=
    33.
    34.     OCR0A=77;
    35.     OCR0B=77;
    36.
    37.     DDRB|=(1<< PB1) | (1<<PB2) | (1<<PB3);   //PWM Pins as Out
    38.     DDRD|= (1<<PD3) | (1<<PD6)|(1<<PD5);
    39. }
    40.
    41.  void SetPWMOutput(uint8_t duty)
    42.  {
    43.      OCR1A=duty;
    44.      OCR1B=duty;
    45.      OCR2B=66;
    46.  }
    47.
    48.
    49. void USART_Transmit( unsigned char data )
    50. {
    51.     /* Wait for empty transmit buffer */
    52.     while ( !( UCSR0A & (1<<UDRE0)) )
    53.     ;
    54.     /* Put data into buffer, sends the data */
    55.     UDR0 = data;
    56. }
    57.
    58. unsigned char USART_Receive( void )
    59. {
    60.     /* Wait for data to be received */
    61.     while ( !(UCSR0A & (1<<RXC0)) )
    62.     ;
    63.     /* Get and return received data from buffer */
    64.     return UDR0;
    65. }
    66.
    67. int main(void)
    68. {
    69.     //    char d=0;
    70.         InitPWM(); // calling the driver for the pwm signal
    71.     //    USART_Init(25);
    72.     while(1)
    73.     {
    74.       // d = USART_Receive();
    75.     SetPWMOutput(127);
    76.     //USART_Transmit(d);
    77.     //_delay_loop_2(3200);
    78.     }
    79. }
    80.
    ignore the uart functions ..they are for interfacing xbees .
    Help me out pleease? 0:)
    If someone has an alternative successful code i'd be very thankful! :)
    Thanks soo much.
