PWM of AC?
Discussion in 'The Projects Forum' started by germeten, Nov 1, 2015.
  1. germeten
    Apr 18, 2014
    26
    Hi, I'd be interested to build a PWM adjustment/detector of the high points of an AC wave. I tend to think this would require a flip-flop and bi-directional peak detector of some kind that can be spread out from the highs to encompass greater or lesser amount of the wave. Can anyone point me in a direction where to start with such a project, or if something exists already? I did find a Chinese researcher who wrote a paper on such a generator but it's tied up in the legal copyright world of pay-for-me.
    I found this from another thread of similar topic, but am having trouble making full sense of it or how to incorporate it.
    http://www.realtechsupport.org/UB/MM/practical things/AC_powerlines.pdf
  2. wayneh
    Sep 9, 2010
    12,374
    3,226
    I have no idea what that means. What are you trying to do?
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Its hard to make out what you're describing - but sounds a bit like triac phase control.
    If you're trying to do peak detection, its fairly difficult. For a degree or two of phase angle, its almost DC at the tips of the peaks.
    If the frequency is stable; you can detect the zero crossing point more precisely and predict the peak point with a fixed delay.
    KJ6EAD likes this.
  4. germeten
    Apr 18, 2014
    26
    OK, any idea how to go about that? I believe the link I posted describes that but it's still greek to me. I assume the detector/delay chip must power a mosfet and not sure how to incorporate both to run on and pass AC. Ideally I'd like to catch the high points with even distribution of pulses on both sides of peak (adjustable.) I don't think TRIACS can do that.
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    The question still remains: Why bother?
    KJ6EAD likes this.
  6. germeten
    Apr 18, 2014
    26
    If you mean why bother responding, I couldn't agree more.
  7. GopherT
    Nov 23, 2012
    6,303
    4,021
    I think the "why bother" means, what advantage would your wish have over what is done with triacs? If you have a reasonable answer, then it may be worth the bother. Until then, why bother with the extra complexity other than the fact that it makes a more symmetrical wave and some people deem that to be prettier than a triac option.
  8. germeten
    Apr 18, 2014
    26
    I want to be able to PWM an AC wave.
  9. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Why? What is the ultimate purpose? Is it to control power in a load?
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The "why bother" is because I don't think there is a single device, or a simple circuit that will do what you want it to do. Could some complex collection of devices and circuits do the job? Maybe, but nobody can see the purpose of developing such a circuit. If you can't articulate a reason then
  11. ian field
    Oct 27, 2012
    4,447
    791
    It would be hard to do that other than threshold detection on both rising and falling slopes - and if the sinewave amplitude isn't absolutely stable, that would be futile.
  12. germeten
    Apr 18, 2014
    26
    Yes.
  13. crutschow
    Mar 14, 2008
    13,475
    3,361
    Then for us to invest time and effort in helping you, we need a reason as to why the PMW approach is better then the standard SCR approach.
    Or is this just an academic exercise?
  14. ian field
    Oct 27, 2012
    4,447
    791
    As a theoretical exercise, its mildly entertaining - but only till the novelty wears off.......................
    What I've suggested so far is; zero crossing detection and delays to generate a trigger at a phase angle past the zero crossing.
    A more complex solution would be a PLL frequency multiplier.
    Set the VCO to some binary multiple of the AC frequency and divide it down to the AC frequency to feed into the phase comparator alongside the AC.
    The VCO running at some multiple of the AC frequency provides a chain of clock pulses that can effectively be used to divide up the AC wave into segments. From this point the complexity starts loose. For high resolution (lots of segments) I'd suggest an EPROM lookup table - feed a binary word to the address pins to select a particular pattern of bits to select switchin points on the AC wave.
    For low resolution a diode matrix may be sufficient instead of an EPROM lookup table.
  15. tcmtech
    Nov 4, 2013
    2,107
    1,747
    I use a similar method for Grid Tie Inverter operation, to convert DC into AC and push power back into the AC lines, to set the zero cross dead band lower limits and prevent over current issues with the switching devices.
    It's pretty easy to do with nothing more than basic op amp comparator circuits.
  16. germeten
    Apr 18, 2014
    26
    Your first method is described in any earlier thread on AAC, similar topic, others here have already contributed to. I found some link references to delay circuits while theoretically simple, aren't easy to execute for beginners like me. Frequency doublers and comparators are even more complex, and cumbersome. Somehow I feel instinctively that detecting voltage level for on/off switching is more straight-forward. Simple dialing up or down the voltage detection would automatically capture more or less of the wave. The challenge is it working under either polarity. And lastly, I'd like to keep it as small as possible even while passing big loads.
  17. GopherT
    Nov 23, 2012
    6,303
    4,021
    Still no justification for trying to do this? Novelty has worn off for now. Thanks for stopping by.
  18. germeten
    Apr 18, 2014
    26
    I'd be interested to see how you do this.
  19. germeten
    Apr 18, 2014
    26
    "Justifications" you're funny. Why not talk about prohibitions? Makes as much sense. If you don't know how to do something, or don't want to, why not leave it to someone who does? Please don't strain your brain on my account.
  20. djsfantasi
    Apr 11, 2010
    2,900
    874
    Because there is not always one answer to our questions. Without knowing the "justification", it may not be possible to identify which answers apply. Otherwise, simply reverse engineer a household dimmer. I too am interested in this question, so that I may control AC from a micro. So let's not let this get personal.
