PWM motor control
Discussion in 'General Electronics Chat' started by Tobias, Mar 4, 2010.
  1. Tobias
    Thread Starter Active Member
    May 19, 2008
    158
    I am wanting to control a 24v motors speed. I am using a PIC 16F886 with a P type MOSFET. Using the CCP1 output to control the MOSFET with HPWM. What is a good frequency to use? Any suggested MOSFET part numbers?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why a P-ch MOSFET?
    It would be easier to use an N-ch MOSFET; that way you can switch the low side of the load. Besides, N-ch MOSFETs have better specs than their complementary P-ch versions.
    If you are wanting to go higher than a few hundred Hz, you're going to need a gate driver IC.
    What is the motor's current at stall?
  3. Tobias
    May 19, 2008
    158
    What would you suggest based on the attached document? What are the benefits of higher than 200 hz?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you have the PWM above 25kHz, it will be beyond audio range, so you won't hear it. However, it takes a fairly capable gate driver to turn a MOSFET on and off quickly at those speeds.
    At low PWM speeds, you'll have more losses in the motor, and you'll hear the motor "sing". However, you can get by without a gate driver.
    I don't see stall current listed. Highest current shown is 7.14A near the bottom. Stall current will be several times that.
  5. Tobias
    May 19, 2008
    158
    Thanks, I will look around for a N-Type MOSFET IC Driver schematic. Any suggestions on MOSFET and drivers?
