Hey all,
Just need someone to reinterpret some details for me from this datasheet for a 24 channel constant current led driver, DM163.
Basically the device lets you shift in data which is used to output PWM to 24 LEDs. I want to use it (or many of them) with an FPGA to create a small LED display.
Here is my major issue:
If I wanted to use just 8 bits of data for each LED and didn't care about the dot correction, can I shift in 6 ones into the dot correction register at the start of the program and then forget about that register for the rest of the program? Or is it a case of reloading the dot correction every time I put any new data in?
I just don't want to waste half my clocks shifting in ones every time for something I don't really need/want, and I know that my display size is dependent on how long it takes to shift a frame into the drivers.
Also, can I do it the other way around and make the 8 bit register all ones and use the 6 bit register for image data?
Hopefully one of you bright sparks will sort this out for me.
Cheers, Josef
Cheers, Josef
