pwm generation in microbasic compiler for pic
Discussion in 'Embedded Systems and Microcontrollers' started by majoka, Sep 11, 2009.
  1. majoka
    Sep 10, 2009
    8
    i need to generate a 38khz pwm clock signal using ccp module for pic16f873A.i am using microbasic compiler for pic but i can not succeeded to do it .i want that continuously 38khz signal generated by RC2 pin by hardware timer of pic and i dnt care that in programming
    i try it with this code
    TRISC.2 = 0 ' CCP1 (PortC.2 = Output)
    Pwm_Init(38000) ' Set the PWM frequency to 38000 hz
    Pwm_Change_Duty(63) ' 25% duty cycle
    Pwm_Start ' Start outputing the pulse stream
    but its not working
    anyone can help me
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. majoka
    Sep 10, 2009
    8
    i am using 4mhz crystal but may b in future i will use 20mhz
  4. Tahmid
    Jul 2, 2008
    344
    27
    Here's the program
    Code ( (Unknown Language)):
    1. program osc_38 'I used mikroBasic PRO for PIC v2.50
    2.
    3. main:
    4.
    5.      PWM1_Init(38000)
    6.      PWM1_Set_Duty(64) 'For mikrobasic 7.2 this becomes PWM1_Change_Duty(64)
    7.      PWM1_Start
    8.      TMR2 = 0                            ' ADDED THIS LINE
    9.
    10.      while true
    11.            nop
    12.      wend
    13.
    14. end.
    Unless you write 0 to TMR2, there becomes a problem. So, hope this helps.
    Same code for 4MHz and 20MHz, only change the clock in mikroBasic project.
  5. Tahmid
    Jul 2, 2008
    344
    27
    Over here, for 50% duty cycle, CCPR1L should be 13, not 52 (4MHz), CCPR1L = 66, CCPR1H = 0 (20MHz)
  6. Tahmid
    Jul 2, 2008
    344
    27
    Hi Majoka,
    Have you succeeded in generating the 38khz pwm clock signal using ccp module for pic16f873A in Mikro Basic?
