PWM from PICAXE 18M2 amplified by MOSFET IRF640
markodaguy
Joined Mar 24, 2015
9
A couple of months ago I posted a forum asking about how I could amplify the PWM from a PICAXE 18M2 where I received positive responses (http://forum.allaboutcircuits.com/t...mer-amplifying-light-bulb.118185/#post-930297). After building the rest of the circuit and trying solve all the problems within the circuit, I find myself coming back to the 18M2 subsystem where I can't solve the PWM amplifying problem.
I connected the IRF 640 as I was shown in the previous forum (subsystem diagram attached) however the filament light has a small dimming range, from 6.34V to 6.74V to be exact. The PWM signal itself straight from the 18M2 has a consistent voltage range from 0V to 4V, meaning that I believe that there are no problems with the code itself as it works fine when I have a diode connected to the PWM output (without using a MOSFET, no power amplification). I want the subsystem to work so that I can dim the filament bulb from 0V-7V (or around that range). I will upload pictures of the actual connected MOSFET connected within the subsystem.
As well I have tried to use a 2N2222 transistor to act as a power amplifier, however it has low switching voltage and the voltage across the light bulb is constantly varying when I am not changing the readadc value (which is the voltage from the potentiometer), I believe this occurs due to the transistor heating up quite a lot however I am unsure. Below I will also attach the code that I set up for the PICAXE 18M2.
init: ;initial code, setting parameters for pwm
pwmout b.6, 50, 300 ;generating pulse width modulation at b.6 of the 18M2 driver which is pin 12
main:
readadc c.2, b0 ;analogue signal at c.1 (pin 16)
pwmduty b.6, b0
debug
goto main
For the code above, after "pwmout", I'm unsure what values I should use for dimming the light bulb, these values were obtained from trial and error, and used what looked had the best dimming effect.
dannyf
Joined Sep 13, 2015
2,197
Your mcu, at 4v, may not be able to turn on the MOSFET fully. Run it at higher rail, or use a mosfte with lower threshold voltage, or use a driver.
Alec_t
Joined Sep 17, 2013
14,335
As danny says. The IRF640 has a Vgs(thr) which can be as high as 4V, so the 4V gate voltage may result in only a tiny drain current.
34,470
As noted, you need to to use a MOSFET with a lower Vth.
They are called logic-level MOSFETs and fully turn on at a Vgs of 5V or less (look at the Vgs used for specifying the Ron value on the data sheet).
If you read your referenced forum thread again you will see that the recommended MOSFET was changed to the logic-level IRL640.
markodaguy
Joined Mar 24, 2015
9
Thanks all.
May I just ask if I were to use a logic FET, would I still need to use a driver to run it? If not do I just connected it normally ?
Dodgydave
Joined Jun 22, 2012
11,307
same connection, it just works from a 1v gate , the irf series need 3v minimum, you could use a pnp to pull the gate to positve, or use a tip121 darlington.
