PWM for LEDs - non-LED resistor wattage?
Discussion in 'The Projects Forum' started by jaesun, Mar 25, 2009.
  1. jaesun
    Mar 24, 2009
    I just want to apologize in advance because this might be an incredibly dumb question.
    I've gone through the PWM circuit designs which I want to use for 2 blue LEDs (3v voltage drop and 100 mA current rating) in series using a 12 volt wall wart. I figured out that I'll need a 62 ohm 1 watt resistor.
    I can't figure out the wattage of the other resistors. Is it 1/8 watts? Should I use 1/4 or 1/2? I want to use the PWM circuit for a few other LED projects, so I'd like to know if changing the source voltage and LED parameters will change the wattage required for the other resistors.
  2. jaesun
    Mar 24, 2009
    my bad, I neglected to mention that this is for the PWM circuit using the 555.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Where is the circuit or a link to the circuit?
  4. jaesun
    Mar 24, 2009
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I suggest 1/4W resistors. 12V * 12V / 1KΩ = more than 1/8 Watt.
