PWM fan controller
Discussion in 'General Electronics Chat' started by arthur92710, Feb 26, 2008.
  1. arthur92710
    Thread Starter Active Member
    Jun 25, 2007
    307
    I need to be able to adjust the speed of my fans in the computer. I hear that PWM is an efficient way to adjust the speed of the fans. I need to adjust the speed of 4 fans. Is this a good circuit? Also is there a way to lower the number of components?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    9 components? not bad.
    http://www.allaboutcircuits.com/vol_6/chpt_6/9.html
    i think you need to choose the frequency carefully. i know for heavy inductor fans (automotive cooling fans) we drive them around 30Hz. pc fans may like to be driven at 100Hz, etc. experiment and see.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you look at the link to my simple PWM circuit, you would see that it has only six components not including the load, and all except for the power MOSFET are quite basic components.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Arthur, are your fans brushless motors? I think that many small fans such as those used in computers are brushless.
    If they are brushless, I don't know if PWM will work as well as a variable DC drive such as an one based in LM317.
    Sgtwookie, is that your understanding?
    hgmjr
  6. DC_Kid
    Feb 25, 2008
    641
    9
    the 9 had transistor driver in the count...
    6 or 9, does it really matter, still a low count of parts....
  7. arthur92710
    Jun 25, 2007
    307
    Yes they are brushless.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Actually, I'm not sure offhand. :confused:
    National's datasheet for the LM317 has a couple of switched-mode supply schematics. Those would be more efficient than simply using an LM317 by itself - but actually, a DC-DC converter would be more efficient than that.
    OTOH, one could always build a comparator circuit to control a MOSFET to keep the voltage across a cap in an approximate range. A stripped-down switching power supply, if you will.
