PWM fan control-problem
Discussion in 'General Electronics Chat' started by somlioy, Nov 12, 2011.
  1. somlioy
    Jul 28, 2010
    22
    Hi
    Trying to get the hang of this pwm fancontroller.(For a computer fan). With the cap the fan stops at like 75% duty cycle while without the cap it stops at 10% but there's this buzzing sound.
    The output on the mosfet looks weird aswell.
    Two first shots are captured on the input on the drain-pin while the third one is captured on the drain pin.
    Can anyone tell me what I've missed? :s
    Edit: Crap, missed the schematic;
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Have a look HERE under suppressing PWM noise on page 2 to adjust your gate RC.
    somlioy likes this.
  3. nigelwright7557
    May 10, 2008
    488
    71
    I wouldnt have bothered with the RC. Just pulsing the motor will alter its speed. Also it means the FET is on or off rather possibly in its linear region which might cook it.
  4. bountyhunter
    Sep 7, 2009
    2,498
    507
    Most DC fans have controller IC's built in. If you mess around with trying to pulse the voltage or current into them, they won't work right.
  5. somlioy
    Jul 28, 2010
    22
    Ye, without the RC there's this annoying noise from the PWM pulses aswell.
    Thanks for answers anyway. I'm going to try different RC setups unless someone else has something to say.
  6. R!f@@
    Apr 2, 2009
    8,793
    771
    Three problems..
    1. What type of fan u are using.
    2.What is the PWM frequency?
    3.Remove RC at gate...just put a 47ohm resistor in series with gate only. Gate charge together with RC is driving the fan haywire. :D
    {ed}
    for q 2....around 1KHz... hey wizard, that is the audible range.
