PWM - Duty cycle - Is finer adjustment possible?
Discussion in 'Programmer's Corner' started by atferrari, Apr 2, 2005.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,669
    784
    Today I started to experiment with PWM in a 16F877. Got both PWM modules working in minutes.
    While period can be finely ajusted with 10-bits precision, the duty cycle seems more complicate due to the two LSB in CCP1CON<5:4>.
    I have no specific application in mind but when tried to increase/decrease the duty cycle value I've realized that trying to change it down to the LSB would demand too much code other than INCF / DECF.
    For an eventual application requiring a fast adjustment, is it any way to do it or we have to accept adjusting only the value in CCPR1L?
    Agustín Tomás
  2. nerd256
    Member
    Nov 21, 2004
    23
    You can't modify the PWM duty-cycle to its 10-bit precision using only CCPR1L with the 16F87x series. However, with many other PICs, you can specify the justifiction of the 10-bit value, as in CCP1CON<5:4> can represent the LSBs or the MSBs.
    However, when you're running this thing at 20MHz, a few extra lines of code won't make that much of a difference, as it takes a while for the CCP module to settle anyways.
    Lets say the MSBs are in DCH, and the two LSBs are in DCL<5:4>
    you can change the PWM with
    movfw DCH
    movwf CCPR1L
    movfw CCP1CON
    andlw b'11001111'
    addwf DCL, W
    movfw CCP1CON
    However, you are correct in saying that INCF and DECF are slower, but the alternative is quite short
  3. atferrari
    Jan 6, 2004
    2,669
    784
    Yes, that's the point! The time frame I am working in counts a lot!
    Thanks.
    Agustín Tomás
