Pwm dspic 33 and CANbus comunication
Discussion in 'Embedded Systems and Microcontrollers' started by Manuel_Mac, Mar 1, 2013.
  1. Manuel_Mac
    Dec 14, 2012
    5
    Hi, I'm trying to drive a motor using a dspic33. I'm using PWM to control the motor and CANbus to communicate with PC (that's a school project, I have to use these things). Both pwm and CAN work fine, but when I try to send the duty cycle value with CAN, pwm doesn't work. I've used debugger and that's what i've found:
    - CAN buffer is read by DMA
    - Firmware read DMA and set the duty cycle register
    - DMA buffer is cleared
    - PWM module clear the duty cycle register too
    That's the main:
    while(1)
    duty=ecan1msgBuf[1][3];
    if(duty!=0)
    P2DC1=duty*100;
    And here pwm initialization:
    P2TCONbits.PTEN=0; //bisable pwm
    P2TCONbits.PTOPS=0b0000; //postscaler 1:1
    P2TCONbits.PTCKPS=0b00; //prescaler 1:1
    P2TCONbits.PTMOD=0b00; //freerunning mode
    P2TPER=499; //pwm period value bits
    P2FLTACONbits.FAEN1=0;
    PWM2CON1bits.PEN1H=0;
    PWM2CON1bits.PEN1L=1;
    PWM2CON1bits.PMOD1=1;
    PWM2CON2bits.IUE=0;
    PWM2CON2bits.OSYNC=0;
    PWM2CON2bits.UDIS=0;
    P2DC1=0;
    P2OVDCONbits.POVD1H=0;
    P2OVDCONbits.POVD1L=1;
    P2TCONbits.PTEN=1;
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    By "work fine" I assume you have some way to see that pwm and CAN both are working by themselves?
    Make a debug build and drop a breakpoint where the code detects a CAN reception, and track what actually gets received, how it is handled, and where it goes.
  3. Manuel_Mac
    Dec 14, 2012
    5
    Yes, they both workby themself.
    The only thing I can see using debugger is that once DMA is cleared, Duty cycle register is cleared too.
    I'va also tried to use this firmware:
    while(1)
    P2DC1=500;
    pwm works until DMA register is cleared, than duty cycle is set to zero and then is set to 500.
  4. Manuel_Mac
    Dec 14, 2012
    5
    Problem solved: DMA module was faulty.
