pwm driving servo on dspic
Discussion in 'Embedded Systems and Microcontrollers' started by bassplayer142, May 13, 2010.
  1. bassplayer142
    Thread Starter Active Member
    Jan 2, 2007
    89
    I was finally successful to drive the clock how I wanted it and now I am going trying to drive a pwm servo. I already got the right frequency and pulse width which I checked with pickit2 logic tool. So when I connect the output pin to a servo the led which is also connected flickers really fast and the servo just spins around until it binds. My guess is that here is some external addon needed. Thanks for the help.
  2. Markd77
    Sep 7, 2009
    2,803
    594
    If it is a hobby servo and you are not varying the pulse width then that is what I would expect to see.
    The pulse should be 1-2 ms every 20ms. A 1ms pulse moves it to one side, a 2ms moves it to the other, 1.5ms would be the middle, etc.
  3. bassplayer142
    Jan 2, 2007
    89
    Thanks! I guess I had some false information...
