PWM Driver--Need Help
Discussion in 'The Projects Forum' started by Mustafatarhan49, Jan 1, 2013.
  1. Mustafatarhan49
    Aug 16, 2012
    56
    Hi all,
    I need a current controlled pwm driver for PMOS. The Vds is 60V, Imax =>50mA,and Vref is 5V Vout= 6V, L = 1.02mH Cout= 5uH. Rload =100ohm.
    Previously, I was planning to use voltage controlled pwm driver, but it is not widely used as much as Current controlled is used. I will use this pwm driver after the compensation network in the LTspice or cadence simulation.
    Thanks for your help!
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    Post the circuit diagram of what you have.
  3. Mustafatarhan49
    Aug 16, 2012
    56
    please see the attached file.
    I have another question regarding to the error amplifier compensation.
    I found that circuit from the web and I have no clue how did they calculate the compensation components. Can you also please help me how can i find this compensation values?
  4. Mustafatarhan49
    Aug 16, 2012
    56
    any idea#? :D:D
