I'm working on a controls project and could use a little help.
What would be the word on using the load output from a PWM dimmer - I'm using an Abeltronics DIM11 - as an input to a relay coil? The attached drawing should help explain why I want to do this. Basically, the momentary button Im using to control the DIM11 is a two-color illuminated Bulgin button that needs a DPDT relay to control the color. I need a signal to indicate the state of the load (on or off) to determine the color I should display, and by far the simplest way to do that is to use the load line as the input to the relay. Im just not sure what effect the dimming would have on the coil.
Help?
Thanks a ton.
-Ben
PS - Sorry about the crummy scan of the drawing.
PPS - I note that I didn't draw the (-) side of the coil going to ground, but assume it does.
Help?
Thanks a ton.
-Ben
