Suppose there are two DC motors controlled by PWM designed for the same application but they are made by different companies. One motors starts to limit its voltage and current draw after 67% duty cycle while the other continues to respond to increases in duty cyle. What could be the issue with other one? Less efficient circuity ?? Different transistors ??
Kindly advice someone..Thanks!!
