PWM control for 3 HP DC motor; Snubber Help needed
Discussion in 'General Electronics Chat' started by jkc8560, Aug 18, 2013.
  1. jkc8560
    Aug 18, 2013
    I am developing a speed control for a 3 HP compound shunt wound motor. The armature and field both require variable power control as the application requires the utilization of field weakening for short term high speeds. I built my prototype around the IXYS IGBT # IXA60IF1200NA as final drivers, it is a bit overkill but I like the packaging. I used a 800 V PRV 30 amp fast recovery diode as a snubber across the field and armature winding’s.. All went well on my 1/4 HP test motor but when I tested on the application 3 HP motor the armature recovery diode shorted after 10 minutes, which, in turn, shorted my IGBT.. The PWM frequency was 88 hz as this seems to work well with larger motors.. I usually stick to developing programs and control circuits but I got stuck with this project.. Any Ideas on a better snubber circuit????
  2. shortbus
    Sep 30, 2009
    4,086
    1,664
    Show a schematic of how/what you've done so far.
