PWM audio driver
Discussion in 'The Projects Forum' started by yardleydobon, Sep 6, 2011.
  1. yardleydobon
    Apr 19, 2009
    19
    I want to amplify PWM audio I'm outputting from a microcontroller. I want to play it on an 8ohm 0.5W speaker. Can someone recommend how I should do this?
    I think something like a class D amp output stage chip is what I need, but I can't find one that meets my requirements. I need it to run at 5V. Does anyone know of one that will work for me?
    I tried making a push pull circuit out of 2N7000s but it was still quiet. Would I have better luck with different transistors?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Show a schematic, and we might be of more help.
    Pulse Width Modulation
    It sounds like you need a different driver, something more push pull-ish.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You might just use an RC low-pass filter to change the PWM to a pseudo-sine wave, and just use an inexpensive LM386 audio amplifier.
