That's correct.If I understand your question correctly, you want to have the output of one RC PWM channel converted to a clean on-off TTL signal, correct?
Can you make a quick sketch, even on paint? I don't understand the top line of your picture.Many years ago, I met a scan pulse should be change to the control signal as your needed, the difference is that your pulse isn't fixed.
I haven't try your PWM pulse yet, if you want then you can try it.
1N4148x1, Rx2 , Cap x3, calculating the values to match your need.
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Jake Hertz
