pwm and compare in pic16f877
Discussion in 'Embedded Systems and Microcontrollers' started by roven, Oct 6, 2006.
  1. roven
    Oct 1, 2006
    hi! can pls anyone help me w/ pic16f877, i'm a newbie. i'm using the compare and pwm feature together. i'm using the counter mode of compare and i have a problem with CCPR1L. My CCPR1L is not a fixed value, i would like to write a new value everytime a compare occurs(i.e. everytime the CCPR1IF is set). But the problem is that when i write to it, the TMR1L seems to get written the same value.
    How do i change CCPR1L without affecting TMR1L? any suggestions? i cud post my code if you like. Thanks in advance!
