pvdf tube as an led driver?
Discussion in 'The Projects Forum' started by djimb, Jul 26, 2009.
  1. djimb
    Jul 26, 2009
    i've been trying to find information about the output of pvdf piezo elements in the interest of using a tube as an acoustic resonator (specifically a didjeridoo) that would drive led's when it produces a note. Unfortunately i haven't been able to find much. i was able to find a thread regarding the activation of led's with a piezo disc, and have looked over the schematic found here: http://www.discovercircuits.com/DJ-Circuits/door-knock.htm that was linked in that post, so i know the basic principle is possible. ultimately my question is whether a pvdf tube would be usable as a piezo element, and if so how would one go about connecting electrodes to it to run the led's...
    any help is much appreciated.
    -Jim
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    So are ou wanting to add electronics and a battery to drive the LED as shown? A simple speaker and an active filter would do pretty much the same thing, Google color organ.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Might not a microphone do the trick more simply? The difference in energy coupled through a door by a knock and a note in a tube is probably several orders of magnitude.
  4. djimb
    Jul 26, 2009
    thanks for the replies. I'll look over the color organ schematics i found. ultimately i'm looking to keep the circuit light to avoid any damping of the vibration in the tube, hence my desire to use piezos rather than a microphone. I was kind of hoping that i could use the entire tube as a piezo, as i'd like to mount the led's directly onto the tube so that they'll light up when it's played.
    thanks again,
    -Jim
