PVDF impact sensor
Discussion in 'The Projects Forum' started by chrispedersen, Aug 23, 2013.
  1. chrispedersen
    Aug 23, 2013
    12
    Sooo.. I am a complete novice, in way over my head.
    I got pretty excited by the ability of PVDF to generate a piezo electric effect.
    Details here:
    www.media.mit.edu/resenv/classes/MAS836/Readings/MSI-techman.pdf‎
    I was looking to use the pvdf film as a simple switch. However, it seems that that the output of this switch may be unreliable due to low pass filter effect. At least, so I was warned.
    Can someone help me understand this: It is suggesting the need for a huge Giga Ohm impedance on the input.
    However, here: www.media.mit.edu/resenv/classes/MAS836/Readings/MSI-techman.pdf
    Page 43, ff: it suggest that the pvdf films are suitable for piano keys which is my intended project.
    This
    again suggests problems with detecting strikes, or low frequency events.
    So. I'm all confused. Are 3mm x 12 mm film segments suitable for detecting a keystrike/deflection?
    What should I do about the impedance, if I wished to incorporate this into an arduino project?
    Thanks a ton in advance.
  2. wayneh
    Sep 9, 2010
    12,392
    3,246
    You may need a ultra high impedance op-amp as shown in some of the circuit examples. Last time I went looking for a high impedance op-amp, I found the LMC6035 or LMC660. I never actually used either of them.
  3. chrispedersen
    Aug 23, 2013
    12
    Is there a way to determine easily if so? The papers suggest that oscillators may not work well.
    I'm looking at the op amps..
    Can you perhaps suggest a circuit? Will an ultrahigh impedance affect the input side of the arduino?
  4. wayneh
    Sep 9, 2010
    12,392
    3,246
    No, the idea is that the op-amp will sit between the sensor and anything else, allowing you to eliminate the problem with the sensor's very high impedance. When I read that even an oscilloscope probe might be enough load to distort the sensor output, that's what tells me that you probably need a high-impedance op-amp.
    Do you already have these things? You could spend some time experimenting with the circuits offered in that write-up. The stuff starting on p.39 is helpful.
  5. chrispedersen
    Aug 23, 2013
    12
    Yeah, I 'm a big proponent of dive right in.
    However, these bimetalized sheets are almost $200. I'm trying to get samples first, and solicit input before I drop the cash.
  6. wayneh
    Sep 9, 2010
    12,392
    3,246
    Well, they definitely ought to work. I noticed in the final pages they list a number of application such as keypads. For that kind of pricing, the company can likely help you a bit, maybe even provide sample application circuits for that type of application.
