PV system operation at low irradiance levels
Discussion in 'The Projects Forum' started by daengg, Mar 16, 2016.
  1. daengg
    Mar 8, 2016
    8
    I have designed a PV system which like conventional systems has a Boost converter followed by an inverter. The output of 230V (AC) is achieved for irradiance of 1000 W/m2 to 600 W/m2. However, after that from 500 to 200 W/m2, the system has to be overmodulated which should not be done to get the required output. Simple duty cycle variation is not working for the lower irradiance levels. Please suggest how to fix this problem.
    Thank you.
  2. #12
    Nov 30, 2010
    16,676
    7,321
    Either get the sun to be brighter or use more solar panels.
    wayneh and nsaspook like this.
  3. wayneh
    Sep 9, 2010
    12,379
    3,235
    That's what I was thinking but I stayed silent.
    Think about it: Over the life of the panel, what would be gained from a slight optimization at conditions where almost no power is available? Is it worth your time to design for these conditions? It's the squeal of the pig. Let it go.
  4. SLK001
    Nov 29, 2011
    850
    242
    What is the average solar incidence for your area of the world? Are you asking too much from your panel?
