Pussy Beware!
Discussion in 'Math' started by studiot, Mar 3, 2009.
  1. studiot
    Thread Starter AAC Fanatic!
    Nov 9, 2007
    5,005
    515
    They've counted the cats in Llanfair
    Which number a third of a square
    If a quarter were slain
    Just a cube would remain
    How many, at least, must be there?
    Old but good question.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Thought this out, don't ask me for an equation. :eek:
    108 (assuming no partial cats were slain)
  3. wr8y
    Sep 16, 2008
    232
    108 is a 1/3 of 324.
    324 is 18 squared - ok so far.
    If a quarter were slain, that would be 3/4 times 108 = 81.
    Just a cube would be there
    81 is 4.3267487 to the 3rd power.
    This is not a "cube", 2 cubed is 8 but this is just a number cubed.
    I think you are wrong - or am I confused?
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I got 972 cats.
    John
  5. Ratch
    Mar 20, 2007
    1,068
    To the Ineffable All,
    The answer is 972 cats. Here's why. You have to find out what number makes a perfect cube root of 3x/4. So x has to complete the cube and be divisible by 4. The first number that does that is 36. So three quarters of 36 is 27, which is a perfect cube. The second test is whether 3 times the number is a perfect square. Three times 36 is 108 which is not a perfect square, so the number 36 fails.
    The next number that completes the cube and is divisible by 4 is 3x9x9x4 = 972 . Three quarters of 972 is 729, which is a perfect cube of 9. Three times 972 is 2916 which is a perfect square of 54. That proves that 972 is the smallest number that satisifies the conditions of the problem.
    Ratch
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    I am wondering if I misread the verse.
    First Condition: They've counted the cats in Llanfair
    NumberOfCats\Rightarrow  \sqrt[]{\frac{Perfect Square}{3}}
    Second Condition: If a quarter were slain
    PerfectCube=\sqrt[3]{\frac{NumberOfCats}{4}}
    Modifier: How many, at least, must be there?
    To me, this implies the first two aren't sequential, but two statements, such as:
    "Joe is Taller than Jill, Mary is Taller than Todd. Name them in order of height"
    Rather than finding a condition where two of the sentences are true.
    --ETA: On The Other hand, If you are a Sadistic type, your answer is correct. :D You musta been the kid that kept running up in class to look inside Schrödinger's box.
    --ETA AGAIN! OK, I WAS WRONG! I Forgot the first sentence already whacked most the kitties.
  7. studiot
    Nov 9, 2007
    5,005
    515
    You folks were quicker off the mark with this one.
    Well done Ratch
    Edit: sorry and John.
  8. fx12
    Mar 4, 2009
  9. studiot
    Nov 9, 2007
    5,005
    515
    Welcome to AAC, FX12
    I didn't claim originality and I didn't find it on the internet. The ditty is much much older than the net.
  10. thatoneguy
    Feb 19, 2009
    6,357
    718
    You used google, and didn't post before Ratch (or anybody... Welcome!)
    I proudly displayed my idiocy in public. It was fun writing in TeX though. :)
    So you have a plane on a treadmill.....
  11. fx12
    Mar 4, 2009
    thatoneguy "idiocy..." not at all you made a real attempt and came close.
    If I were to say that you were the one to come closest to the answer-because studiot, Ratch (not saying they did but it is possible) and I found the answer on the net-would you still say "idiocy..." My point was to show that we can not compare ones knowledge, IQ etc because we are all on the net?
  12. jpanhalt
    Jan 18, 2008
    5,699
    909
    Ratch,
    Thank you for explaining my answer, and as usual, you are right.
    The way I reached that answer: x= # of cats, a and b are variables. x, a, and b are integers.
    1) x = 1/3a^2
    2) 3/4x = b^3
    3) 4b^3 = a^2
    I found solutions to equation #3 and tested them in equation #1. One can rule out certain values for "b" immediately by inspection and logic, like 4. I didn't consider primes for "b" because of equation #2. 8 was too similar to 4. It just seemed that "b" might be 9 or 12; although, I did try 6 too.
    Once 9 was found to be viable for "b", the rest of the problem was solved.
    John
  13. b.shahvir
    Jan 6, 2009
    444
    can someone call the PETA guys pleazzzz ? :D
  14. wr8y
    Sep 16, 2008
    232
    After getting a "B" in College Algebra and an "A" in Precalculus last year (working on an ASEET), I hang my head in shame for not being able to do that.
    Thanks! That was a nice flashback to Mr. Lee's classes....
  15. thatoneguy
    Feb 19, 2009
    6,357
    718
    True.
    I'm also a newbie, but have seen that Ratch has a great way of explaining things correctly, with the right answer. I don't doubt he could work the problem without references though, and I should have thought before posting the second time, my first answer seemed to easy.
