Push pull power amplifier
Discussion in 'General Electronics Chat' started by arfarfarfarf, Mar 26, 2012.
  1. arfarfarfarf
    Mar 10, 2012
    17
    HELP! We need to produce sound to a speaker by using a push pull power amp. The problem is, the speaker's impedance (8ohms) is very small compared to the circuit's output impedance (about 36ohms) that's why we have very low output voltage. Without the 8ohm speaker we have about 200 gain but with the speaker we have a less than 1 gain. what could we do with our power amplifier circuit. It is a push pull using 3904 3906 with diodes 1N4148. Thanks!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    As always, schematics?
    My first inclination is a matching transformer. You could wind a toroid from scratch.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You must not have a circuit, because you didn't post a schematic.
    If you DO have a circuit, then post its' schematic. Without that, we're just wasting each others' time.
  4. arfarfarfarf
    Mar 10, 2012
    17
    Sorry I forgot! Here's my schematic
  5. bountyhunter
    Sep 7, 2009
    2,498
    507
    Here is an audio amp that will easily drive eight Ohms or much lower impedances.
