Hello all,
I'm working on a 12+VDC project and need some help figuring out the circuit. Basically, I want to control the ON/OFF states of a standard Bosch automotive type (SPDT) relay with a momentary push button switch that is supplied with a switched 12+VDC feed. Here is how I want the circuit to work:
1. Push the button and the relay turns ON
2. Push the button again and the relay turns OFF.
