Push button accumulating timer circuit
Discussion in 'General Electronics Chat' started by doubledutch1, Sep 19, 2009.
  1. doubledutch1
    Sep 19, 2009
    I am trying to figure out a circuit that will activate a relay for two hours each time the button is pressed up to at least four times (8 hours).
    So if it is pressed once it will activate the relay for two hours and if it was pressed twice 4 hours, etc.. Up to 8 hours minimum.
    I’ve been successful using a MC68RS08KA2 MCU to do the delay for 2 hours but I can’t figure out a loop to accumulate additional time. I’ve also used a 555 to get the two hour delay but not a way to get the additional time.
    Does anyone have a suggestion of a simple circuit that will do the same thing with or without a 555 or MCU? Is there another chip out there that would make this simpler?
    Is there a circuit that will allow a 555 or another chip to repeat based on a button input?
    Any creative thinking would be appreciated.
    Thanks in advance.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    555 timers don't work so well for long time delays.
    Why don't you post your source code for the MCU?
    Please use the [ code] and [ /code] blocks so that it will format correctly.
  3. nanovate
    Distinguished Member
    May 7, 2007
    665
    Make a little state machine:
    pseudo-code
    Code ( (Unknown Language)):
    1.
    2.
    3. while(TRUE)
    4. {
    5.     if(button_pressed == TRUE)
    6.     {
    7.         debounce();
    8.         wait_til_button_released();
    9.         state++;
    10.     }
    11.
    12.     if(timer_expired && state !=0)
    13.     {
    14.         state = 0;
    15.         do_stuff();
    16.     }
    17.
    18.     switch(state)
    19.     {
    20.         case 0
    21.             reset_timer();
    22.         case 1
    23.             start timer();
    24.         case 2
    25.             add time():
    26.         .
    27.         .
    28.         .
    29.         default
    30.             state = MAX_NUMBER_DELAYS;
    31.
    32.     }
    33. }
    34.
    This is just a rough outline.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Wookie's right, though with extra circuitry you could do it. I figure (off the cuff) around 4 chips to make the circuit.
    Also, every time you press the button do you want the timer to reset (start timing from that point on) or from the 1st button press?
  5. doubledutch1
    Sep 19, 2009
    Here's the code.
    The delays right now are set for a one minute delay instead of the two hour delay. I did this for testing purposes.
    I hope it formats properly.
    Thanks, for your help.
    ; This program counts the number of times a button is pushed and activates a relay for 2 hours
    ; for every push.
    ; Pin 1 = PTA2 (RESET)
    ; Pin 2 = PTA3 (BKGD)
    ; Pin 3 = VDD + 5 volts
    ; Pin 4 = VSS Ground
    ; Pin 5 = PTA5 (Relay)
    ; Pin 6 = PTA4 (Relay Active LED)
    ; Pin 7 = PTA1 (Push Button Counter)
    ; Pin 8 = PTA0 Pin (Not Used)
    ; export symbols
    XDEF _Startup, main
    ; Export both '_Startup' and 'main' as symbols. Either can
    ; be referenced in the linker .prm file or from C/C++ later on
    ; Include derivative-specific definitions
    INCLUDE 'derivative.inc'
    ; Variable/Data Section
    CLKST EQU 2
    ORG RAMStart
    counter: DS.B 1
    counter2: DS.B 1
    counter3: DS.B 1
    ; Const Section
    ConstSection: SECTION
    ; Code Section
    ORG ROMStart
    ; Peripheral Initialization
    init:
    ;CONFIGURES SYSTEM CONTROL
    mov #HIGH_6_13(SOPT), PAGESEL
    mov #$03, MAP_ADDR_6(SOPT) ; Disables COP, enables BKGD (PTA3) and RESET (PTA2) pins
    ;CONFIGURES CLOCK (FEI Operation Mode)
    mov #HIGH_6_13(NV_ICSTRM),PAGESEL
    lda MAP_ADDR_6(NV_ICSTRM)
    sta ICSTRM ; Sets trimming value
    clr ICSC1 ; Selects FLL as clock source and disables it in stop mode
    clr ICSC2 ; ICSOUT = DCO output frequency
    wait_clock:
    brset CLKST,ICSSC,wait_clock ; Waits until FLL is engaged
    ;CONFIGURES TIMER
    mov #$70, MTIMSC ; Enables interrupt, stops and resets timer counter
    mov #$FF, MTIMMOD ; MTIM modulo = 256 counts before interrupt
    mov #$08, MTIMCLK ; Selects fBUS as reference clock (8 MHz)
    ;CONFIGURES I/O CONTROL PORT
    mov #$31, PTADD ; Configures PTA0, PTA4 and PTA5 as output,PTA1 as an Input
    mov #HIGH_6_13(PTAPE), PAGESEL
    mov #$04, MAP_ADDR_6(PTAPE) ; Enables Pull UP on PTA2 (RESET)
    ;CONFIGURES KEYBOARD INTERRUPTS (KBI)
    mov #$00, KBIES ; Selects Falling Edge/Low on Pin
    mov #$02, KBIPE ; PTA1 as KBI input
    mov #$06, KBISC ; Clears any false interrupts
    clr PTAD ; Clears PTA port
    rts
    ; Entry Point
    _Startup:
    main:
    bsr init
    clr counter
    clr counter2
    clr counter3
    clr coins
    main_loop:
    loopRelay:
    mov #HIGH_6_13(SIP1),PAGESEL
    brset 4,MAP_ADDR_6(SIP1),RelayOn ;If button goto Relay on
    bra loopRelay ;No button continue to wait
    RelayOn:
    bset 2, KBISC ;Clear KBI Interrupt
    bset 5, PTAD ;Turn on Relay LED
    bset 4,PTAD ;Turn on Relay
    StartDelay:
    mov #$60,MTIMSC
    bclr 4,MTIMSC ; Start MTIM counter
    LoopDelay:
    wait
    lda counter
    cbeqa #255,Delay2
    inc counter
    bra StartDelay
    Delay2:
    clr counter
    lda counter2
    cbeqa #5,Delay3
    inc counter2
    bra StartDelay
    Delay3:
    clr counter
    clr counter2
    lda counter3
    cbeqa #5, RelayOff
    inc counter3
    bra StartDelay
    RelayOff:
    clr counter
    clr counter2
    clr counter3
    bclr 5,PTAD
    bclr 4,PTAD
    bra loopRelay
  6. doubledutch1
    Sep 19, 2009
    Thanks everyone,
    I couldn't figure out how to program a state machine with my limited code experience. I didn't get any feedback on my code so I guess no-one else figured it out either. Thanks anyways.
    I did find a CSS555C timer that says it works for long delays. Anyone have experience with those that can provide feedback?
    Thanks again,
    Rod
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    The core problem with 555's and long time delays isn't the timer, it's the capacitor. Large electrolytic caps tend to leak. Couple that with a large resistor, and you have a RC circuit that doesn't follow theory very closely.
    You never answered my question about the reset.
    My inclination is the 4060, because it has 12 ripple counter flip flops after a basic RC oscillator.
    The other idea is a simple digital counter. I like the thought about the microcontroller. Much simpler overall.
  8. doubledutch1
    Sep 19, 2009
    Thanks Bill,
    I didn't answer your question because I thought it was addressed in the original post. My mistake.
    I'd like the timer to start with two hours and and add an additional 2 hours to the original start for each push of the button. So if I pushed the button at 8 am it would run until 10 am but if I pushed it again at any time during the first count down (between 8 am and 10 am) it would run until noon.
    The CSS555C timer has an internal trimmed capacitor that is supposed to be very stable and predictable for accurate timing. Anyone have any experience with it to determine if it would work reliably for a two hour delay?
    I have the 2 hour delay working with a microcontroller, I just can't figure out the code to get it to add an additional 2 hours after the original start. You can see the timed loops I used in one of my previous post.
    Rod
