purpose of resistor in circuit
Discussion in 'General Electronics Chat' started by aamirali, Jul 15, 2014.
  1. aamirali
    Feb 2, 2012
    415
    What is the purpose of 1M resistor in circuit attached.
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    No purpose except high impedance isolation. I would have chosen a capacitor instead of a resistor.
    anhnha likes this.
  3. wayneh
    Sep 9, 2010
    12,377
    3,231
    It works with the 2M resistors to condition the signal being applied to the op-amp. If it were a low value, that node would be completely dominated by the resistor divider voltage and the 2M resistors would be irrelevant.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    The circuit and the graphs do not agree.
    That 1M has a very clever purpose.
    With 125V peak on the input, the 98K/2K divider passes 2/100 of the input, or a 2.5V peak signal. That's 5V peak to peak. The input impedance is approximately 2K (exactly 2K || 98K or 1.96K).
    The two 2M resistors bias the op amp input to Vref/2 or 2.5 VDC. Note the Thevinin equivalent of the 2M resistors is a 2.5V source with a 1M source resistance.
    With an input resistance of 2K and an output resistance of 1M one can ignore the input resistance. Thus the 5V peak to peak is divided by 1M/2M or it is cut in half to 2.5V peak to peak, riding on the 2.5V bias.
    Upper signal is 2.5V - 1.25 = 1.25V
    Lower signal is 2.5V + 1.25 = 3.75V
    That doesn't quite agree with the graph. To get that one needs to rescale the resistors for a DC level of 1.25V, yet keep the 1M Thevinin resistance.
    I leave that calculation as an exorcize for the reader.
  5. aamirali
    Feb 2, 2012
    415
    @ErnieM
    I think you get some calculations wrong.
    I have simulated the circuit & results are in page 1 of attached pdf.
    I have then applied superposition by grounding ac source & saw that, with dc source = 5V,
    Vbias = 1.25V (not 2.5V as you have mentioned) & Vth resistance = 500K approx (not 1M as you had mentioned).
    Both the above results are in page 2 & 3 of pdf.
    Page 4 of pdf shows ac effect when dc is zero.
  6. NorthGuy
    Jun 28, 2014
    611
    121
    1M is used to equal impedance from the "sensor" with impedence of 2M/2M dividers. With equal impedance on both sides, the circuit avarages "sensor's" voltage with 2.5V coming from the divider.
    When AC is at +125V, it is 125/50 = 2.5V on the left side of 1M resistor. When mixed with 2.5V from 2M/2M divider, it gives 2.5V.
    When AC is at -125V, it is -125/50 = -2.5V on the left side of 1M resistor. When mixed with 2.5V from 2M/2M divider, it gives 0V.
    Ernie's explanation is correct, but numbers are wrong.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    After seeing all of the monkey motion that was necessary to analyze this simple circuit in that other "toy" simulator :D, I simmed it using LTSpice.
    Note how simply LTSpice finds the transfer function of this circuit.
    It seems important to determine what value of V(in) makes V(out) = zero and 5V, because those are the limits of what a voltage follower powered with 5V could follow (assuming a rail-to-rail in/out) opamp.
    This is done simply by sweeping V(in) from -300V to 510V in steps of 5V, and then using the cursor placement to ask what are the input voltages that get the output to near 0V and 5V. Results are shown in the cursor box. Note the slight offset...
    LTSpice simply does 402 .DC solutions, and plots the node voltages vs the independent simulation variable, namely V(in). What could be simpler...
  8. NorthGuy
    Jun 28, 2014
    611
    121
    Mike, these resistors are 2M :)
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    That's not LTSpice's fault...
    Here is is again, this time with 2meg resistors...
    Also, I reduced the sweep range of V(in) from 120V to 130V, and plotted V(out) and I(R3). Note that for V(in)=125, V(out) is exactly 2.500V and I(R3)=zero...
