Purpose of pouch, digikey
Discussion in 'General Electronics Chat' started by aamirali, Aug 4, 2014.
  1. aamirali
    Feb 2, 2012
    415
    I have got some components from digikey. Along with the components there is small pouch. What is this.
      File size:
      595.7 KB
      35
      File size:
      505.9 KB
      29
  2. mitko89
    Member
    Sep 20, 2012
    123
    19
    According to the quoted standard (http://www.jedec.org/sites/default/files/docs/jstd033b01.pdf), those cards would indicated whenever your parts were exposed to humidity. If the indicator shows pink, you should dry the package before using the enclosed materials. Or at least that is what I understood from the brief skimming of the document I linked.
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Perhaps the pouch contains dessicant?
  4. ronv
    Nov 12, 2008
    3,401
    1,459
    The pouch is desicant. It absorbs moisture to keep the parts dry.
  5. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    The pouch keeps the contents dry, while the card indicates when the humidity is within the recommended range for soldering. If outside that range, dont solder.
    Some of these parts are also time sensitive, in that once exposed to free air (package is opened) they should be soldered within a given recommended time period (like 6 weeks) for optimum results.
  6. MrChips
    Oct 2, 2009
    12,636
    3,454
    I save all the little pouches of desiccant. You can rejuvenate them by putting them in the oven.
  7. MrSmoofy
    Member
    Jul 28, 2014
    112
    5
    Don't let kids/pets play with/eat the content of the pouches either.
  8. bombledmonk
    Nov 17, 2006
    The Moisture Sensitivity Level (MSL) procedures are generally for going through a reflow soldering process. For non-production hand-soldered items a person can normally ignore that precaution.
