true.it influence the power factor as well same as the capasitance
I've corrected your original text in the quote. You really should spend some time working on your communication skills. It will greatly enhance your credibility.That means I just get a rough idea about the signal I will get from the simulation? Yes
I can't compare my result with the simulation? You can but expect there to be significant differences.
Then how can i know whether my system is accurate or not? You can only be certain if you build one and test it against your requirements.
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
