Purchasing SMD resistors kit
Discussion in 'General Electronics Chat' started by HMartins, Apr 12, 2013.
  1. HMartins
    May 10, 2011
    21
    Hi.
    I need to buy some SMD resistors kit.
    I need something around 1210, 1% but I don't need all the values, E12 or E24 would be OK. I don't want to spend too much.
    I've been looking a supplier for this but I didn't find anything quite like the above. Indeed I need 1%, at list 2%, 5% if there is no other way (I will have to select the resistors by hand in some circumstances).
    Can I have some help, please?
  2. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Have you tried EBay? See if a search for "smd resistor kit" turns up anything useful to you. I did see some 1206 1% kits such as this one.
    Digikey has a portal to Portugal (it's even in Portuguese!). You could search resistor kit and see who makes what (but what I saw was expensive).
    These days it's hard to find anything worse then 1% resistors. The process is just too good to make worst than that.
  3. HMartins
    May 10, 2011
    21
    ErnieM likes this.
