Puppy Linux - handy if your hard drive fails
Discussion in 'Off-Topic' started by Markd77, Feb 12, 2012.
  1. Markd77
    Thread Starter Senior Member
    Sep 7, 2009
    2,803
    594
    I've just tried puppy linux for resizing a partition, but it would also be useful for anyone if their hard drive fails or their operating system stops working.
    It loads from CD or USB into memory, is only 130 megabytes, autodetected everything and was very user friendly (apart from having to download a browser).
    If you get it and burn it to a CD then if something goes wrong you can get on the internet and find out how to fix it or order a new drive.
    Other versions of Linux can do the same but most are larger.
    If you download something or change settings you can save it on a USB stick or apparently on the CD.
    http://www.puppylinux.com/
    (I used the Lucid Puppy version).
  2. nerdegutta
    Dec 15, 2009
    2,567
    806
  3. Markd77
    Sep 7, 2009
    2,803
    594
    Yes, <snip> Small Linux looks like a good alternative to Puppy and the Ultimate Boot CD would be a good add on to either.
  4. Markd77
    Sep 7, 2009
    2,803
    594
    I've been messing a bit more with Puppy and I've now got it set up on an old Compaq I found in the street. 500MHz, 256MB of ram and a 10 Gig hard drive.
    I've managed to set it up so that it boots from a 4 Gig USB stick instead of the hard drive and the swap file is also on the USB stick.
    The performance isn't great by modern standards, but on a machine this old it's pretty good.
    Now it runs very quietly and probably uses hardly any power so I could leave it on all the time. Now I just need to think what to use it for.
    I'm just about to set it up so I can connect to the desktop from my main PC, I've done it before, so it should be easy.
    <ed> Success! Second screenshot is running in a remote desktop from my main PC. </ed>
