Punchdown Tool
electronewb
Joined Apr 24, 2012
260
Anybody here has any experience with punchdown tools for keystone jack termination? I have this tool http://www.amazon.com/Punch-Down-Impact-Blade-Cutter-HT-324B/dp/B001TPIX54 with the 110 blade using those keystone connectors from Belden http://www.mayflex.com/products/cop...6-unscreened-rj45-keystone-jack---mdvo-style/ Pretty simple concept to wire but my issue is no matter how hard I push on the tool the wires don't stay in place They kind of go inside the "clamp" but just a little bit of pull the the wire(s) comes off. Bad technique or wrong tool?
Kermit2
Joined Feb 5, 2010
4,162
The most likely cause would be incorrect wire gauge. Too small to be exact.
What gauge wire are you using and do you have any one gauge number smaller?
EX. if you are using 28 AWG, try 26 AWG
electronewb
Joined Apr 24, 2012
260
Good question I don't have the cable with me I could let you know tomorrow. So basically the jack and the cable has to be a perfect match?
Dr.killjoy
Joined Apr 28, 2013
1,196
Damn your bringing back memories lol
They use them on a 44 punch down block and others but they are like an impact tool almost like a automatic center punch but they have different head ... To me it sounds like it' malfunction or needs to be adjusted to right setting ..
electronewb
Joined Apr 24, 2012
260
I actually traded the tool for another one from the store where I bought it but I haven't tried the new one yet. The new one is much harder to bring down way more resistance. The reason why I'm asking what could be wrong is I've watched maybe 5 videos on youtube and these guys were nailing those jacks with such ease meanwhile I have to put all my weight on it and I can remove the wire by just puling on it lightly .
gerty
Joined Aug 30, 2007
1,305
Is yours spring loaded? Does it make a 'click' when it bottoms out?
It's an impact tool, the cheaper ones are not spring loaded and you have to smack'em with the palm of your hand. All of this providing you have the correct wire of course..
tubeguy
Joined Nov 3, 2012
1,157
As you suspect, it should be fairly straightforward.
Please don't be offended, but are you aligning the blade parallel wiith the wire, and do you have the notch on the tool centered on the terminal slot?
Even the simple non spring-loaded tools that come with many jacks require only a firm but not "all your weight " pressure to seat the wire. When the wire is seated properly it will be at the bottom of the terminal slot.
