Hello Folk, My first time here. I need help. I have a transformer that takes in 220VAC and puts out 12 or 24 VAC. I need to talk that output and change it to a DC that keeps changing its polarity every few minutes. The output needs to stay between 500mA and 650mA. I need to be able to feed at least three parallel loads with that range of current. Have looked at switches and relays but nothing makes sense to me. The circuits I come up with keeps becoming complicated. Can any one help plz??? I am not an electronics person so please keep that in mind when you suggest solutions
Hi Folks,
I had posted a question earlier. Your responses made me realize that I need to do a better job explaining what I am doing and look for help with. Attached picture does it better.
Summery:
I have 220VAC~240VAC coming out of the wall. Need to change it to clean 9VDC~21VDC. Then I need a way to flip polarity every minute of so. Only one polarity is needed at a time. Load is dumb. It just sits and burns. Current range required at load is 500mA~650mA. The picture explains more.
Following questions are on the picture too:
There could be more loads (three total perhaps). Is there a way to keep current to each load the same 500mA~600mA range regardless of how many loads are there? (say max three) I can put a turn knob to set flow of current depending on how many loads there are.
What would it take to create all this for more loads? Which component would have to be altered?
Could this work better if I choose a transformer with different output capability (higher or lower power or output)?
Is there a way to reduce the frequency of the AC current from 50~60 Hertz to maybe 1~5 Hertz. If that can be done I can go directly from transformer to selection knob. (then there is no need to convert to DC or to switch polarity) The current at load needs to stay the same though.
Hi Folks,
Summery:
