pulsing 40 kvdc
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Aug 1, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    i need help i need to do pulsing power supply vo=40kvd and io=10 ma and the pulsing rate for about 1 khz so is there any mofset or igbt can i use it to do pulsing
  2. praondevou
    Jul 9, 2011
    2,936
    489
    What is this circuit for? Do you need a constant current of 10mA during 500us (1kHz @50%) ???
    You will have some difficulties finding a component for this voltage.
    Do you already have a power supply that can output this voltage?
    TAKYMOUNIR likes this.
  3. #12
    Nov 30, 2010
    16,671
    7,314
    I believe there is no such thing as a 40KV semiconductor. My guess would be a very expensive vacuum tube because mechanical switches can't go that fast.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    40kv @ 10mA is 400 Watts. Are you sure about that requirement?
    You will likely need to use a transformer, like an automotive ignition coil, to create such pulses at that high of a voltage. There are plenty of relatively low-voltage switches/transistors/MOSFETs/IGBT's that are suitable for the primary side of the coil.
    Here are some OnSemi part numbers for their ignition IBGTs:
    NGD15N41A: Ignition IGBT, 15 A, 410 V
    MGP15N40CL: N-channel Ignition IGBT, 15 A, 410 V
    NGD18N40A: Ignition IGBT, N-Channel, 18 A, 400 V
    NGB8204N: N-Channel Ignition IGBT 18 A, 400 V
    NGB8202N: N-Channel Ignition IGBT 20 A, 400 V
    NGB8207AN: N-Channel Ignition IGBT 20 A, 365 V
    TAKYMOUNIR and #12 like this.
  5. #12
    Nov 30, 2010
    16,671
    7,314
    Are you in sneaky mode, wookie?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Always. Otherwise, I get an unmanageable number of PM's and E-mails. :rolleyes:
  7. #12
    Nov 30, 2010
    16,671
    7,314
    Awww. You're just too lovable!
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    What is the duty cycle. That answer makes all the difference in the world between peak power and average power.
  9. TAKYMOUNIR
    Jun 23, 2008
    351
    i need to do test for power supply so i need to do this kind of test
  10. strantor
    Oct 3, 2010
    4,302
    1,989
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    see post 10.
    80KV MOSFET.
    same company makes 120KV semiconductors as well.
    #12 likes this.
  12. #12
    Nov 30, 2010
    16,671
    7,314
    Well there you go! PPM Power in UK. Just strip everything after "UK" off the link and you have the corporation.
