Pulsed Led Ccs
Discussion in 'General Electronics Chat' started by haha11, Aug 29, 2014.
  1. haha11
    Dec 10, 2008
    9
    i have used a fast rise fall square waver transistor circuit to get the
    pulses like 30Hz
    one led shows the pulses
    SMd LED5050 x 2 PCS is the main lighting device
    for test purposes
    fed to the normal CCS (constant current source)
    --background
    * i came to know that LEDS can be pulsed with 2x or more current
    pulses like 100hz to 4Mhz are used in driver chips
    So made this amateure combo circuit .
    Question :
    I want to make the led take 150% current from rated 20mA ,
    is the combo working as pulsed oscillator
    Canwe avoid the CCS
    and safely pulse the LED with small changes
    is it good to pulse with 150% power for SMD 5050 leds
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    IIRC: Sharp have published some useful appnotes on pulse/duty cycle drive for LEDs
  3. haha11
    Dec 10, 2008
    9
    any links....for some specific info on SMD5050
    SMD 5050 led is good one procured from industrial supply
    today i pulsed them with 159mA current 2 modules in parallel
    they seem to light pretty bright..no heating for 20min test
    not sure if it may degrade life?
