Pulse without a 555 and a Counter issue.
Discussion in 'The Projects Forum' started by haxxx, Feb 28, 2009.
  1. haxxx
    Thread Starter Active Member
    Feb 14, 2009
    35
    1.)When my counter IC (4029)counts from zero to one pin 7 Goes high (7.5v)
    I want to use that rising edge to pulse a second circuit. Is there any other way to get a pulse other than using the 555, if not is it okay to invert that pin 7 output and go straight to pin 2 Of the 555.
    2.) Also another little problem, A backward count from zero to nine also makes pin 7 go high. I understand y it happens based on the counters 4 outputs but is there any way around it, that is: “zero to one: yes” “zero to nine: no”.
    Thanks,
    Haxxx.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Post your circuit's schematic, preferably in .PNG format.
  3. haxxx
    Feb 14, 2009
    35
    I based it on the attached circuit but i want to use pin 7 on the 4029 to pulse a relay when the count moves from zero to one. and preferrably not
    when it counts backwards from zero to nine.
    Thanks.
    Haxxx
  4. SawabyPlus
    Member
    Feb 27, 2009
    14
    u can AND pin 7 and the up/down' signal so that gate output doesn't go hi unless counting upwards
  5. haxxx
    Feb 14, 2009
    35
    Thanks a lot man, any solutions for part one of the question.
    Haxxx
